Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
  1. Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame. Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
    • Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
  2. Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device. Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  4. Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver. One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty. Use the plastic removal tool to work pry the mid-frame from the device.
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  5. Carefully use the pointed end of the spudger to disconnect the ribbon connections on the motherboard. Carefully use the pointed end of the spudger to disconnect the ribbon connections on the motherboard. Carefully use the pointed end of the spudger to disconnect the ribbon connections on the motherboard.
    • Carefully use the pointed end of the spudger to disconnect the ribbon connections on the motherboard.
  6. Wedge the plastic opening tool between the motherboard and front plate to dismount the motherboard and chassis from the front plate of the phone.
    • Wedge the plastic opening tool between the motherboard and front plate to dismount the motherboard and chassis from the front plate of the phone.
  7. Use one side of the tweezers to pry the LCD off of the front plate of the phone. Work in a clean environment and do not touch the inside of the plastic screen cover or the face of the new LCD Screen. These cannot be cleaned once the device is reassembled. Work in a clean environment and do not touch the inside of the plastic screen cover or the face of the new LCD Screen. These cannot be cleaned once the device is reassembled.
    • Use one side of the tweezers to pry the LCD off of the front plate of the phone.
    • Work in a clean environment and do not touch the inside of the plastic screen cover or the face of the new LCD Screen. These cannot be cleaned once the device is reassembled.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
Taylor
1.165 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 16-6, Watkins Winter 2015 Mitglied von USF Tampa, Team 16-6, Watkins Winter 2015
USFT-WATKINS-W15S16G6
2 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 1,614
