Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
    • Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
  2. Note: one of the screws is hidden under a plastic sticker. Remove the five 4 mm screws with a Phillips#00 screwdriver. Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Note: one of the screws is hidden under a plastic sticker.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Remove the battery with plastic opening tool
    • Remove the battery with plastic opening tool
  5. Using the plastic opening tool pry into the bezel to remove the mid-frame Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  6. Once you have separated the mid-frame it should look like this.
    • Once you have separated the mid-frame it should look like this.
    • Replace the old mid-frame with the new one and follow the steps in reverse.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Charles
133 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 8-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 440
