Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
  1. Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame. Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
    • Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
  2. Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device. Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  4. Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver. One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty. Use the plastic removal tool to work pry the mid-frame from the device.
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  5. Lift the speaker from the phone using your fingers or tweezers. Lift the speaker from the phone using your fingers or tweezers. Lift the speaker from the phone using your fingers or tweezers.
    • Lift the speaker from the phone using your fingers or tweezers.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Taylor
1.165 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 16-6, Watkins Winter 2015 Mitglied von USF Tampa, Team 16-6, Watkins Winter 2015
USFT-WATKINS-W15S16G6
2 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 736
