Was du brauchst
Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
Use the plastic removal tool to work pry the mid-frame from the device.
Lift the speaker from the phone using your fingers or tweezers.
2 weitere Personen haben diese Anleitung absolviert.
