Zum Hauptinhalt wechseln
Samsung Galaxy Gear Battery Replacement
Was du brauchst
  1. Samsung Galaxy Gear Battery Replacement, Display Housing: Schritt 1, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Battery Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Gear Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Galaxy Gear Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • After separating the LCD/motherboard from the actual watch itself, the watch should be in two separate pieces.
    • You will only need the watch/strap component so you can set aside the LCD/motherboard component.
  5. Samsung Galaxy Gear Battery Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Gear Battery Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Gear Battery Replacement: Schritt 5, Bild 3 von 3
    • Look for the metal bracket that covers and secures the battery in place.
    • Loosen the bracket by prying underneath the metal plating with the plastic opening tool. Remove the bracket and set it to the side.
    • The battery should now be exposed.
  6. Samsung Galaxy Gear Battery Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Gear Battery Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Gear Battery Replacement: Schritt 6, Bild 3 von 3
    • Notice the leads attached to the base of the watch. You will need to remove this before you pull the battery out.
    • Using the plastic opening tool, pry underneath the leads and disconnect it from the back of the watch.
    • Slowly tug on the "PULL" tag and remove the battery from the watch.
Abschluss
11 weitere Personen haben diese Anleitung absolviert.
Edward Yi
424 Reputation
1 Anleitung geschrieben
Cal Poly, Team 1-9, Maness Spring 2016 Mitglied von Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 Mitglieder
7 Anleitungen geschrieben
4 Kommentare zur Anleitung
WHERE DO I GET A NEW bATTERY & THE TOOLS; IS A COMPLETE KIT AVAILABLE?
rbilello - Antwort Teilen
where do I get the battery & tools
steve ellis - Antwort Teilen
“Parts
No parts required.”
I think a battery is required!
cyberjoe3d - Antwort Teilen
Thank you very much
Adam P NYC
bori0916adam - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 31
Insgesamt: 13,993
