Einleitung
Note: This guide is a continuation off of the display housing removal guide. It is crucial that you follow and complete the prerequisite guide step-by-step.
Use this guide to easily replace a faulty battery or insert a fresh new battery for a longer- lasting, more reliable Samsung Galaxy Gear watch.
Was du brauchst
Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
Use a plastic opening tool to separate the display housing from from the device.
Gently pry back the metal flap on top of the connector.
Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
Look for the metal bracket that covers and secures the battery in place.
Loosen the bracket by prying underneath the metal plating with the plastic opening tool. Remove the bracket and set it to the side.
The battery should now be exposed.
Using the plastic opening tool, pry underneath the leads and disconnect it from the back of the watch.
Slowly tug on the "PULL" tag and remove the battery from the watch.
11 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
where do I get the battery & tools
“Parts
No parts required.”
I think a battery is required!
Thank you very much
Adam P NYC
