Einleitung
To access the interior of the device, the housing that contains the display needs to be removed. This guide will act as a prerequisite for all other guides.
Was du brauchst
Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
Use a plastic opening tool to separate the display housing from from the device.
Gently pry back the metal flap on top of the connector.
Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
