Einleitung
If the motherboard needs to be replaced, this guide will demonstrate how to do so.
Was du brauchst
Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
Use a plastic opening tool to separate the display housing from from the device.
Gently pry back the metal flap on top of the connector.
Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
The motherboard is attached to the display using an adhesive
Using a heat gun, heat up the display for 4 to 5 minutes, making sure the move the heat gun around to distribute the heat around the display. This heats up the adhesive making the motherboard easier to remove
Using a plastic opening tool, carefully insert the opening tool in between the bezel and the motherboard and slide it the entire length of the logic board.
Slowly pry up the motherboard from the display.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Had to build a cradle, keep breaking, do not know out the 5 brass pronges which is pisitive and negative, how is there no schematic of the gear watch??
