Einleitung
This guide is needed if your midframe on your phone is broken or cracked.
Was du brauchst
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
Wedge the blue plastic opening tool in between the front and side panel.
Move the blue plastic opening tool around the edges between the front and side panel.
42 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
anyone can tell me how to swap vibrator motor?
I need some glue to replace the midframe after having changed it?
not necessary
yasir -
