Zum Hauptinhalt wechseln
Samsung Galaxy Grand Prime Earpiece Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: Schritt 2, Bild 1 von 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: Schritt 2, Bild 2 von 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: Schritt 2, Bild 3 von 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: Schritt 3, Bild 1 von 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: Schritt 3, Bild 2 von 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: Schritt 3, Bild 3 von 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: Schritt 4, Bild 2 von 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: Schritt 5, Bild 2 von 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Earpiece Speaker: Schritt 6, Bild 1 von 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Earpiece Speaker: Schritt 6, Bild 2 von 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  7. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Gently pull on the connector with the tweezers until the speaker comes off.
Abschluss
23 weitere Personen haben diese Anleitung absolviert.
Kyle Ruff
6.749 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 17-3, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 39
Insgesamt: 11,792
