Zum Hauptinhalt wechseln
Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
Was du brauchst
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: Schritt 2, Bild 1 von 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: Schritt 2, Bild 2 von 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: Schritt 2, Bild 3 von 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: Schritt 3, Bild 1 von 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: Schritt 3, Bild 2 von 3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: Schritt 3, Bild 3 von 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: Schritt 4, Bild 2 von 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: Schritt 5, Bild 2 von 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: Schritt 6, Bild 1 von 2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: Schritt 6, Bild 2 von 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
Abschluss
30 weitere Personen haben diese Anleitung absolviert.
Kyle Ruff
6.794 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 17-3, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Mitglieder
12 Anleitungen geschrieben
3 Kommentare
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - Antwort
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - Antwort
How to me a memory card a default storage on grand prime
Ayandaundetsco - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 36,257
