Einleitung
This guide is needed when you have a faulty charging port.
Was du brauchst
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
Wedge the blue plastic opening tool in between the front and side panel.
Move the blue plastic opening tool around the edges between the front and side panel.
Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Gently pull on the connector with the tweezers until the speaker comes off.
Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
Unhook the ribbon cable clip to the front camera.
Lift the motherboard up and out of the device.
34 weitere Personen haben diese Anleitung absolviert.
