Einleitung
Outline what you are going to teach someone how to do.
Was du brauchst
Insert a finger nail or plastic opening tool between the back cover and the device.
Gently pry the rear cover off of the back of the phone.
Insert a plastic opening tool between the screen and the back of the device.
Starting at the bottom of the device, gently slide the tool along the edges of the screen.
Gently pry the main assembly from the midframe of the device.
Use the flat end a spudger to disconnect the front-facing camera cable connecter.
12 weitere Personen haben diese Anleitung absolviert.
