Was du brauchst
Insert a finger nail or plastic opening tool between the back cover and the device.
Gently pry the rear cover off of the back of the phone.
Insert a plastic opening tool between the screen and the back of the device.
Starting at the bottom of the device, gently slide the tool along the edges of the screen.
Gently pry the main assembly from the midframe of the device.
Using the flat end of a spudger, disconnect the digitizer cable connector.
Using a plastic opening tool pry between silver digitizer and black back piece.
Slowly slide plastic opening tool around the screen to loosen the adhesive.
19 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
In my Samsung J110h, Some of the right side keys in keyboard not working. They are P, Zero, In message screen, the sending button etc..
I am in desperate need for advice to rectify.
Will somebody help me.
My mail Id”: karupusolai@gmail.com
I was having the display issue. So I bought Samsung Galaxy J1 Screen replacement. And, I replaced it by myself using the information in this.
