Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will assist in the replacement of the Samsung Galaxy J1's volume button.
  1. Insert a finger nail or plastic opening tool between the back cover and the device.
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Using a finger, pull the SIM card down out of its slot. Remove the SIM card.
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  5. Insert a plastic opening tool between the screen and the back of the device. Starting at the bottom of the device, gently slide the tool along the edges of the screen. Gently pry the main assembly from the midframe of the device.
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  6. Use the flat edge of a spudger to push the volume button out. Remove the volume button.
    • Use the flat edge of a spudger to push the volume button out.
    • Remove the volume button.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Sean Kramer
1.233 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S5-G4, Eyestone Spring 2018 Mitglied von USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 9
Letzten 30 Tage: 30
Insgesamt: 851
