Zum Hauptinhalt wechseln
Samsung Galaxy J3 (2016) LCD Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Samsung Galaxy J3 (2016) LCD Replacement, Prepping the device: Schritt 1, Bild 1 von 1
    • It's always good practice to prepare the device before any repairs
    • If the glass is broken or craked I suggest adding tape on the surface in order to prevent risks
    • This device, the glass was fine but the LCD has craked due to unfortunate Flex.
  2. Samsung Galaxy J3 (2016) LCD Replacement, Removing the back cover: Schritt 2, Bild 1 von 2 Samsung Galaxy J3 (2016) LCD Replacement, Removing the back cover: Schritt 2, Bild 2 von 2
    • In order to remove the back cover. Flip the device around and lift the back cover by the little slit on the upper left side
  3. Samsung Galaxy J3 (2016) LCD Replacement, Removing the Battery: Schritt 3, Bild 1 von 2 Samsung Galaxy J3 (2016) LCD Replacement, Removing the Battery: Schritt 3, Bild 2 von 2
    • An unfortunately rare sight nowadays of a removable battery. Remove it by lifting from the lower right corner when there is a little notch
  4. Samsung Galaxy J3 (2016) LCD Replacement, Remove SIM & SD (optional): Schritt 4, Bild 1 von 1
    • This is optional as the cards will not interfere with the replacement.
    • Since the device will be subjet to massive heat. I would still recommand to remove them (just in case)
  5. Samsung Galaxy J3 (2016) LCD Replacement, Detaching the LCD connection: Schritt 5, Bild 1 von 2 Samsung Galaxy J3 (2016) LCD Replacement, Detaching the LCD connection: Schritt 5, Bild 2 von 2
    • The LCD ribbon is very easy to access. Just pop that little door open and you will have access to it.
    • Like always with such device, be careful not to force anything out. You will damage the board if the connector is uncorrectly detached.
    • You can see the water damage indicator there (the white square)
    • There is a another one inside the cover that protect that zone.
  6. Samsung Galaxy J3 (2016) LCD Replacement, Removing the LCD: Schritt 6, Bild 1 von 2 Samsung Galaxy J3 (2016) LCD Replacement, Removing the LCD: Schritt 6, Bild 2 von 2
    • Heat with a heatgun the surrounding of the device. Be careful there are very fragile ribbons hidden away.
    • I suggest starting from the bottom corner and lift the heated glass with a pry tool.
    • It is better to go from left to right as the main LCD ribbon is located on the right top corner
    • I strongly suggest NOT using metal tools (like pictured) as it cut thru the digitizer ribbon when I was around the left top corner
  7. Samsung Galaxy J3 (2016) LCD Replacement, Removing the LCD (2): Schritt 7, Bild 1 von 1
    • You can now detach the assembly from the body by passing thru the connector on the designed whole on the side.
    • The LCD is held by a VERY strong adhesive. Be careful when handling that part.
  8. Samsung Galaxy J3 (2016) LCD Replacement, Placing the new screen: Schritt 8, Bild 1 von 3 Samsung Galaxy J3 (2016) LCD Replacement, Placing the new screen: Schritt 8, Bild 2 von 3 Samsung Galaxy J3 (2016) LCD Replacement, Placing the new screen: Schritt 8, Bild 3 von 3
    • As the reverse of the last step slide the connector in the designed slit.
    • Be careful to make a test fit before adding any adhesive
    • Don't forget to add or align the center key before closing down anything
    • Once placed I suggest adding additional adhesive on the center place to further secure the screen.
  9. Samsung Galaxy J3 (2016) LCD Replacement, Done !: Schritt 9, Bild 1 von 1
    • After re-attaching the LCD. Test the device by powering it back up.
Abschluss
Enjoy your newly repaired device!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Hans
1.920 Reputation
6 Anleitungen geschrieben
Mero IT Services Mitglied von Mero IT Services
Business
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 56
