Was du brauchst
Pull up on the small indention on the right side edge and remove the back portion of the phone.
After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
