Einleitung
This guide will help you fix a broken or shattered screen on your Samsung J3 device.
Was du brauchst
Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
Use your prying tool to slowly pry up on the bottom right corner of the white cable guard, exposing a thin ribbon cable connector.
Pry up the ribbon cable connector revealed from under the cable guard and remove the display from the device.
Clean the residue from the phone edges before re-assembling phone with new screen.
To reassemble your device, connect all cables, apply fresh screen adhesive and follow these instructions in reverse order.
12 weitere Nutzer:innen haben diese Anleitung absolviert.
