Einleitung
Camera Replacement guide for a Samsung Galaxy J3 Emerge Model SM-J327P. Front and back cameras may need replacement if they are cracked. Each camera is found behind the motherboard. You will need time to open the motherboard before replacing the cameras.
Was du brauchst
Heat up the edges of the screen with a hair dryer.
Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
Work the iFixit Opening Tools around the whole screen to break the glue.
Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
Insert the iFixit Opening Pick between the motherboard and the panel.
Work the iFixit Opening Pick around the outside of the motherboard.
