Einleitung
Home Button and Audio Jack guide for a Samsung Galaxy J3 Emerge Model SM-J327P. May need to replace the home button if it is unresponsive. If audio becomes distorted when plugged in to the jack it needs replacing.
Was du brauchst
Heat up the edges of the screen with a hair dryer.
Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
Work the iFixit Opening Tools around the whole screen to break the glue.
Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
Insert the iFixit Opening Pick between the motherboard and the panel.
Work the iFixit Opening Pick around the outside of the motherboard.
Lift up the connector and push it through the motherboard by following the ribbon.
Follow the ribbon and gently pop the audio port out using the iFixit Opening Pick.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
