Zum Hauptinhalt wechseln
Samsung Galaxy J3 Emerge Screen Replacement
Was du brauchst
  1. Samsung Galaxy J3 Emerge Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Screen Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy J3 Emerge Screen Replacement: Schritt 2, Bild 2 von 2
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Screen Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy J3 Emerge Screen Replacement: Schritt 3, Bild 2 von 2
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
PJ Yebisu
256 Reputation
1 Anleitung geschrieben
Cal Poly, Team S19-G2, White Winter 2019 Mitglied von Cal Poly, Team S19-G2, White Winter 2019
CPSU-WHITE-W19S19G2
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
I was using my J3 Emerge last night and all of a sudden the screen just went blank. At first, I could press the power button and I would see the Samsung logo for a split second but now it doesn’t do that. You can tell it is trying to turn on because you can see it change from black to a blue like color. I thought it might be the battery so I took it to a store today to buy a new one but he said that wasn’t the problem. It is charging but I just can’t see anything. Do you think I need a new LCD screen or is it something else? Thank you!
theleachs - Antwort
Gostei da aula parabens muito gratificante.
athoscost - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 2,989
