Einleitung
Speaker replacement guide for a Samsung Galaxy J3 Emerge Model SM-J327P. The speaker needs replacing if the sounds are distorted when speaking on the phone or when music is playing.
Was du brauchst
Heat up the edges of the screen with a hair dryer.
Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
Work the iFixit Opening Tools around the whole screen to break the glue.
Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
Insert the iFixit Opening Pick between the motherboard and the panel.
Work the iFixit Opening Pick around the outside of the motherboard.
Use the iFixit Opening Pick to pry off the speaker from the back side.
Pull out speaker with hands or use tweezers to pull out speaker.
