Einleitung
Sometimes the solution to an issue with battery life is simply just a faulty battery. This guide will enable you to safely remove and replace your phone battery.
Was du brauchst
Turn off the phone.
Use your thumbnail to pry off the back cover.
Remove the battery using your thumbnail.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
