Zum Hauptinhalt wechseln
Samsung Galaxy J3 Luna Pro Front and Back Camera Replacement
Was du brauchst
  1. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement, Motherboard Change: Schritt 1, Bild 1 von 1
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 2, Bild 3 von 3
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 3, Bild 3 von 3
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 4, Bild 3 von 3
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: Schritt 5, Bild 3 von 3
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement, Front and Back Camera: Schritt 6, Bild 1 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement, Front and Back Camera: Schritt 6, Bild 2 von 3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement, Front and Back Camera: Schritt 6, Bild 3 von 3
    • Use a spudger to flip up the retaining flaps on the front and rear camera ribbon cable ZIF sockets.
    • Pull the cables outs of the ZIF sockets.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jay Patel
150 Reputation
1 Anleitung geschrieben
USF Tampa, Team S5-G5, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 1,329
