Zum Hauptinhalt wechseln
Samsung Galaxy J3 Luna Pro Phone Screen Replacement
Was du brauchst
  1. Samsung Galaxy J3 Luna Pro Phone Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Begin by turning your phone off.
    • Turn the phone over and Remove the battery.
  2. Samsung Galaxy J3 Luna Pro Phone Screen Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy J3 Luna Pro Phone Screen Replacement: Schritt 2, Bild 2 von 2
    • Heating the surface of the screen will help with prying it off. It is recommended to use the iOpener.
    • Place the suction cup on the phone screen and press down.
    • insert the plastic opening tool into the crease between the phone and the screen
    • Gently work the opening tool around the phone perimeter while stabilizing the phone screen with your opposite hand.
  3. Samsung Galaxy J3 Luna Pro Phone Screen Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy J3 Luna Pro Phone Screen Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy J3 Luna Pro Phone Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the plastic cover that protects the screen strip
    • Remove the phone screen strip
    • Attach new phone screen in place of the old one.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S5-G5, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
I apologize for not knowing the difference but it is the screen digitizer and the screen lens basically the same thing? My touch screen works but the glass is cracked immensely.
So should I search ebay/amazon parts for this:
Samsung Galaxy J3 Luna Pro Phone Screen Replacement?
Any help is greatly appreciated thank you so much…
Jason
Jason Thompson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 8,602
