Einleitung
Removing the back cover should be the very first thing that you do. This is how you access the battery, SD card, and SIM card. Without taking off the back cover, it is impossible to access other components of the device.
Was du brauchst
Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
