Einleitung
The motherboard is fragile and is a key component to a working phone. The motherboard on the Samsung Galaxy J3 Mission has several components attached to it, including the camera, SD and SIM card readers, charging port, and more. The motherboard allows the CPU, RAM, and computer hardware to communicate with each other.
Was du brauchst
Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
Insert your fingernail into the battery removal slot and pull back until the battery pops out.
Use your finger to slide the SD and SIM card out of the device.
Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
Using a Phillips #000 screwdriver, remove all eleven 5mm screws from the metal panel.
Turn the device over, and push firmly to separate the metal plate from the back paneling.
Carefully lift up the motherboard with your finger starting from the bottom up
3 weitere Nutzer:innen haben diese Anleitung absolviert.
