Einleitung
This guide will walk you through the process of replacing a not working motherboard in a Samsung Galaxy J3V.
Was du brauchst
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to flip tab of the front camera to remove it.
Remove connector tab with spudger then carefully remove headphone jack with tweezers.
7 weitere Personen haben diese Anleitung absolviert.
