Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will walk you through the process of replacing a not working power button in a Samsung Galaxy J3V.
  1. Place your thumb on the top left corner and pry the tab open and lift off the back cover. Place your thumb on the top left corner and pry the tab open and lift off the back cover. Place your thumb on the top left corner and pry the tab open and lift off the back cover.
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
  2. Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver. Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver. Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
  3. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  4. Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards. If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off. If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
  5. After opening the phone, locate the power button on the back frame of the phone. After opening the phone, locate the power button on the back frame of the phone.
    • After opening the phone, locate the power button on the back frame of the phone.
  6. Using tweezers, remove the power button's rubber tabs from the clips holding them. Gently remove the entire button Gently remove the entire button
    • Using tweezers, remove the power button's rubber tabs from the clips holding them.
    • Gently remove the entire button
Abschluss
Carry Corrales
711 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G3, Nance Fall 2017 Mitglied von USF Tampa, Team S3-G3, Nance Fall 2017
USFT-NANCE-F17S3G3
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 5
Letzten 30 Tage: 17
Insgesamt: 491
