Einleitung
This guide will walk you through the process of replacing a not working power button in a Samsung Galaxy J3V.
Was du brauchst
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
After opening the phone, locate the power button on the back frame of the phone.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, remove the power button's rubber tabs from the clips holding them.
Gently remove the entire button
Eine weitere Person hat diese Anleitung absolviert.
