Zum Hauptinhalt wechseln
Samsung Galaxy J5 (2017) (J530F) Display Replacement
Was du brauchst
  1. Samsung Galaxy J5 (2017) (J530F) Display Replacement, Display: Schritt 1, Bild 1 von 1
    • Heat the surface of the display with a heatgun for approx. 2 minutes at 200°C.
  2. Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 2, Bild 1 von 1
    • Insert an iFixit Jimmy between the display and the rest of the device, and carefully cut through the adhesive around the phone.
  3. Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 3, Bild 1 von 1
    • Loosen the display, while still applying heat with the heat gun.
    • The display may shatter.
    • Carefully remove any broken glass with a vacuum.
  4. Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 4, Bild 1 von 1
    • Remove the cover on the display connector.
    • Remove the display connector.
  5. Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 5, Bild 3 von 3
    • Remove remnants of the old display and clean the phone.
  6. Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 6, Bild 1 von 1
    • Leave the original liner on the new display. Plug the new display in and test it.
    • Turn the phone off again.
  7. Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 7, Bild 1 von 1
    • Remove the liners.
    • Stick the new display to the phone.
  8. Samsung Galaxy J5 (2017) (J530F) Display Replacement: Schritt 8, Bild 1 von 1
    • finished
Ziellinie
9 weitere Nutzer:innen haben diese Anleitung absolviert.
de en
100%
Hier starten ›
2 Kommentare
Heißluftgebläse … 404
tcagle53 - Antwort
Quick, simple, easy to follow and to the point guide. Thanks for taking the time to write it. Great reference for my repairs!
Jason - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 75
Insgesamt: 11,635
