Was du brauchst
Remove the back of the device by pulling on the tab in the top left.
Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
Remove single screw from back of device. This is the only screw that must be removed to take off this piece.
Make sure to pull up all of these parts in order to properly take off the next piece.
Pull the blue/green piece away from the black piece. They should not need any force to be removed. The next step will deal with using the green/blue piece from the second picture.
Flip over the piece (180 degrees). Remove the boxed out piece. This is the front facing camera.
Eine weitere Person hat diese Anleitung absolviert.
