Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
Pry open the cover: Carefully work around the edges to remove the back cover completely
Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
Remove single screw from back of device. This is the only screw that must be removed to take off this piece.
Make sure to pull up all of these parts in order to properly take off the next piece.
Pull the blue/green piece away from the black piece. They should not need any force to be removed. The next step will deal with using the green/blue piece from the second picture.
Flip over the piece (180 degrees). Remove the boxed out piece. This is the front facing camera.
Eine weitere Person hat diese Anleitung absolviert.
