Einleitung
This guide will help you replace a cracked or broken screen on your Samsung Galaxy J7.
Was du brauchst
Remove the back of the device by pulling on the tab in the top left.
Pull out the battery by pulling on the bottom left slit under the battery.
Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
Gently lift up the speaker piece and disconnect it from the panel.
Gently lift up the tab of the motor.
Remove the motor from the panel completely to disconnect it.
11 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
I replaced the broken screen....before I saw this. Now my phone will not turn on. what should I do? ruth.fnp@gmail.com
