Einleitung
Use this guide to remove the home button on the Samsung Galaxy J7 V. Make sure the screen is removed first.
Was du brauchst
Insert a Jimmy tool under one of the corners of the display and gently raise the display.
Locate the socket of the home button.
Fit the metal spudger in between the socket and the home button.
Take the metal spudger and slide it underneath the home button.
Lift up until the home button is removed from its socket.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
