Zum Hauptinhalt wechseln
Samsung Galaxy Light Rear Facing Camera Replacement
Was du brauchst
  1. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Back Cover: Schritt 1, Bild 1 von 1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Battery: Schritt 2, Bild 1 von 1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Rear Facing Camera Replacement, Unscrew Midframe: Schritt 3, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Midframe: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: Schritt 5, Bild 1 von 3 Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: Schritt 5, Bild 2 von 3 Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: Schritt 5, Bild 3 von 3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Rear Facing Camera Replacement, Rear Facing Camera: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool to disconnect the rear facing camera from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Geoff Wacker
89.889 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 527
