Zum Hauptinhalt wechseln
Einleitung
Outline what you are going to teach someone how to do.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Samsung Galaxy Light USB Charging Port Replacement, Remove back cover: Schritt 1, Bild 1 von 1
    • Remove the back cover with the opening tool to reveal the battery
  2. Samsung Galaxy Light USB Charging Port Replacement, Remove battery: Schritt 2, Bild 1 von 1
    • Now remove the battery and keep it somewhere safe for now
  3. Samsung Galaxy Light USB Charging Port Replacement, Unscrew motherboard from plastic protection: Schritt 3, Bild 1 von 1
    • Unscrew the nine screws shown with the Philips #0 screwdriver
    • Be sure not to lose any screws
  4. Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: Schritt 4, Bild 1 von 3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: Schritt 4, Bild 2 von 3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: Schritt 4, Bild 3 von 3
    • You must detach and replace the entire motherboard the replace the charging port
    • Slowly lift the motherboard up to pull it off the orange strip
    • Pull slowly, you do not want to break this strip
  5. Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: Schritt 5, Bild 1 von 2 Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: Schritt 5, Bild 2 von 2
    • Due to the connector being sawdered on you must replace the whole mother boar so, insert your new motherboard
    • Make sure you line it up correctly with the orange strip
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Diandra
198 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G2
3 Mitglieder
5 Anleitungen geschrieben
3 Kommentare
sawdered = soldered...Other than that it is pretty straight forward...thank you...
Jeffrey Harp - Antwort
Typo, Step 4:
“You must detach and replace the entire motherboard the replace the charging port”
the = to
(could have been ‘to’ or ‘then’, but last step dictates it means ‘to replace the port’’
Thanks for the excellent and simple guides!
Kim Lindstrom - Antwort
why dont you just replace the charging port??? any good tech should have that skill in the bank 100%
Philip Moskal - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 6
Insgesamt: 1,055
