Einleitung
Use this guide to replace your Samsung Luna LCD display.
Was du brauchst
Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
Place the spudger tool between the LCD and the glass screen.
Slide the spudger tool in between the screen and the display until both are completely separated from each other.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Hola, cual es el numero de parte de la pantalla a reemplazar?
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
