Einleitung
This guide will show you the steps to removing and replacing the earpiece speaker inside the Samsung Galaxy Media Player 5 device.
Was du brauchst
Use a Phillips screwdriver to remove the 10 mm screw near the SD Memory Card port.
White caps cover screws on both sides of the charging port. Use the angled tweezers to remove them.
Using a Phillips head screwdriver, unscrew the two 10 mm screws located on either side of the charging port.
Using the opening pick, pry at the bottom and work around each edge of the device until the front cover and back cover housing is separated.
Using the plastic opening tool, apply an upward force to detach the battery and the tab attached to it.
Using the plastic opening tool, apply an upward force to detach the speaker earpiece.
Use the tweezers to attach the new earpiece speaker in place of the original.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
