Einleitung
This repair guide will give a basic demonstration of how to remove the battery from a Galaxy Mega 2. The repair is fairly simple and does not take too much time. It involves removing the back cover and replacing the battery.
Was du brauchst
On the back of the phone, find the slot at the charging port located at the bottom of the phone.
Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
Once you get the corner released, slide your finger around the outside until the back cover releases.
Locate the battery.
Insert fingernail or plastic opening tool into the slot on bottom of the battery and gently lift up.
Remove the battery.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
