Zum Hauptinhalt wechseln
Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement
Was du brauchst
  1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement, Screen & Digitizer Assembly: Schritt 1, Bild 1 von 1
    • Before beginning, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: Schritt 2, Bild 2 von 2
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: Schritt 3, Bild 3 von 3
    • Use a phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use the pry tool to disconnect the digitizer
  4. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: Schritt 4, Bild 2 von 2
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
    • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
    • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
    • Once heated, gently pull the screen upward.
    • Make sure that the buttons are separating from the adhesive.
  5. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: Schritt 5, Bild 1 von 1
    • Now, seperate the screen from the outside frame of the phone (the bezel).
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
I want to repair my phone
Monirul Islam - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 1,261
