Einleitung
The guide will show the process of safely changing the battery of your device.
Was du brauchst
Before starting, ensure device is completely turned off.
On the back of phone, locate the slot on the top left corner.
Insert plastic opening tool or fingernail and pull up on the back plate.
With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
Insert fingernail into the slot on bottom of battery and gently pull up.
Remove the battery.
8 weitere Personen haben diese Anleitung absolviert.
