Zum Hauptinhalt wechseln
Samsung Galaxy Mega USB Board Replacement
Was du brauchst
  1. Samsung Galaxy Mega USB Board Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Galaxy Mega USB Board Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Galaxy Mega USB Board Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega USB Board Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Mega USB Board Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Mega USB Board Replacement: Schritt 2, Bild 3 von 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega USB Board Replacement, Midframe: Schritt 3, Bild 1 von 3 Samsung Galaxy Mega USB Board Replacement, Midframe: Schritt 3, Bild 2 von 3 Samsung Galaxy Mega USB Board Replacement, Midframe: Schritt 3, Bild 3 von 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega USB Board Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Mega USB Board Replacement: Schritt 4, Bild 2 von 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega USB Board Replacement, USB Board: Schritt 5, Bild 1 von 1
    • This circuit board is the charging port assembly.
  6. Samsung Galaxy Mega USB Board Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Mega USB Board Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Mega USB Board Replacement: Schritt 6, Bild 3 von 3
    • Lift up on the clamp with your finger to disconnect the connector.
    • Lift up on the clamp with your finger to disconnect the connection to the mother board.
    • Grasp cable head and lift up to disconnect the cable head.
  7. Samsung Galaxy Mega USB Board Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy Mega USB Board Replacement: Schritt 7, Bild 2 von 2
    • Use your fingers to gently remove charging port.
Abschluss
10 weitere Personen haben diese Anleitung absolviert.
Aaron Fulton
1.246 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 17-2, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 8,710
