Zum Hauptinhalt wechseln
Einleitung
Is the quality of your photo not up to par?
This simple guide will help you replace the front camera lens for your Galaxy Nexus.
  1. You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
    • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
  2. Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot. Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot. Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
    • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
  3. Insert your finger into the divot of the  battery and pull the battery towards yourself to remove. This is when a new battery will be inserted. This is when a new battery will be inserted.
    • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
    • This is when a new battery will be inserted.
  4. Remove 4.4 mm screws using a PH # 000 as indicated on the picture. Remove 4.4 mm screws using a PH # 000 as indicated on the picture. Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
    • Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
  5. After removing the screws be sure to turn the phone right side up. Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone. Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
    • After removing the screws be sure to turn the phone right side up.
    • Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
    • Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
  6. Unscrew 4.4mm with a PH #000 marked screw. Unscrew 4.4mm with a PH #000 marked screw.
    • Unscrew 4.4mm with a PH #000 marked screw.
  7. With the flat head screw driver pull up the blue connector. With the flat head screw driver pull up the blue connector.
    • With the flat head screw driver pull up the blue connector.
  8. With you finger or prying tool pull back bottom module. With you finger or prying tool pull back bottom module. With you finger or prying tool pull back bottom module.
    • With you finger or prying tool pull back bottom module.
  9. Remove the internal battery using tweezers or your flat head screw driver. There is glue at the bottom keeping battery and chassis stuck together. There is glue at the bottom keeping battery and chassis stuck together.
    • Remove the internal battery using tweezers or your flat head screw driver.
    • There is glue at the bottom keeping battery and chassis stuck together.
  10. Peel the display connector strip off the main circuit board using the tweezers. Peel the USB connector strip off the main circuit board using the tweezers.
    • Peel the display connector strip off the main circuit board using the tweezers.
    • Peel the USB connector strip off the main circuit board using the tweezers.
  11. Remove the antenna using either your fingers or tweezers. Remove the antenna using either your fingers or tweezers. Remove the antenna using either your fingers or tweezers.
    • Remove the antenna using either your fingers or tweezers.
  12. Using tweezers, pull the top circuit board off. Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board. Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
    • Using tweezers, pull the top circuit board off.
    • Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
  13. Use the tweezers flip up the circuit for the front camera. Use the tweezers pull out the front camera. Use the tweezers pull out the front camera.
    • Use the tweezers flip up the circuit for the front camera.
    • Use the tweezers pull out the front camera.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
USF Tampa, Team 4-6, Brown Fall 2014 Mitglied von USF Tampa, Team 4-6, Brown Fall 2014
USFT-BROWN-F14S4G6
3 Mitglieder
1 Anleitung geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 662
