Zum Hauptinhalt wechseln
Samsung Galaxy Note 10.1 2014 Battery Replacement
Was du brauchst
    1. Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: Schritt 1, Bild 1 von 2 Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: Schritt 1, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      Spudger
      $2.99
      • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
      • If possible, consider using the black nylon spudger for a gentler separation.
      Frag FixBot
      Kommentar hinzufügen
    1. Samsung Galaxy Note 10.1 2014 Battery Replacement, Battery: Schritt 2, Bild 1 von 1
      • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
      • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
      Frag FixBot
    2. Samsung Galaxy Note 10.1 2014 Battery Replacement: Schritt 3, Bild 1 von 1
      Phillips #000 Screwdriver
      $5.49
      Frag FixBot
    3. Samsung Galaxy Note 10.1 2014 Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Note 10.1 2014 Battery Replacement: Schritt 4, Bild 2 von 2
      Spudger
      $2.99
      • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
      • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
      Frag FixBot
Abschluss
27 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G6, Leahy Spring 2017 Mitglied von USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Mitglieder
7 Anleitungen geschrieben
5 Kommentare zur Anleitung
Step 1 you have to show the back cover to remove. Showing the front side is confusing.
After step 4 there should be a step 5 to show how to disconnect the white connector with the colored wires: it took time to discover that you have to lift the 2 side clips, and not to pull…
prisca - Antwort Teilen
Just followed your instructions. Used a online kit with a guitar pick-like spudger. Had to wrestle with it slightly, but everything worked out perfectly to your instructions.
Matt - Antwort Teilen
You said it was like a guitar pick so I used a guitar pick. Worked pretty well. Guitar pick is bent up but they are cheap.
Stephen Nichols - Antwort Teilen
Followed the instructions. Worked nearly perfectly. The last step is a bit tricky. Just look at the new battery to understand the system.
Eramur - Antwort Teilen
Something I won’t be doing again. It was very annoying to do and nerve racking to complete. Was a pain to snap back together.
Bradley Carr - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 73
Insgesamt: 24,033
