Zum Hauptinhalt wechseln
Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement
Was du brauchst
    1. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: Schritt 1, Bild 1 von 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: Schritt 1, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      Spudger
      $2.99
      • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
      • If possible, consider using the black nylon spudger for a gentler separation.
      Frag FixBot
      Kommentar hinzufügen
    1. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: Schritt 2, Bild 1 von 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: Schritt 2, Bild 2 von 2
      • Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
      • Remove the one 3mm screw on the top left side of the device with the same method.
      Frag FixBot
    2. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: Schritt 3, Bild 1 von 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: Schritt 3, Bild 2 von 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: Schritt 3, Bild 3 von 3
      • Remove the gray rubber piece.
      • Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
      • Remove the right speaker unit.
      Frag FixBot
    3. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: Schritt 4, Bild 3 von 3
      • Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
      • They are the black pieces at the top left and right corners of the device that have metal squares on them in the middle.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G6, Leahy Spring 2017 Mitglied von USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Mitglieder
31 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 49
Insgesamt: 2,197
