Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This explains how to gain access to components behind the motherboard.
  1. Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Slide your fingernail or plastic opening tool along the edge of the rear case. Lift the case gently from the base.
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base. Lift the battery out of its recess.
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  5. Place your fingernail in the groove of the stylus pen.
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  6. Remove the twelve 4mm Phillips #00 screws from the back chassis.
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  7. Insert the plastic opening tool into the Stylus Pen placement holder.
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  8. Remove the single screw beside headphone jack. Remove the single screw beside headphone jack.
    • Remove the single screw beside headphone jack.
  9. Use tweezers to remove both antenna clips. Use a spudger to disconnect six cable connectors.
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  10. Pull up on the motherboard with tweezers.
    • Pull up on the motherboard with tweezers.
Abschluss
71 weitere Nutzer haben diese Anleitung absolviert.
Brittany Gail
8.318 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 2-2, Blackwell Fall 2014 Mitglied von USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Mitglieder
25 Anleitungen geschrieben
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - Antwort
I can replace motherboard sm-n9005 with motherboard sm-n900
yacine - Antwort
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
Nippy Preet -
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 24
Letzten 30 Tage: 124
Insgesamt: 46,760
