Einleitung
Here you can learn to remove the rear case of your phone.
Was du brauchst
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
29 weitere Nutzer:innen haben diese Anleitung absolviert.
