Einleitung
Use this guide to replace the front-facing camera on your Samsung Galaxy Note 4.
Was du brauchst
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery.
Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Grasp the cap of the S Pen and remove it from its slot in the midframe.
Insert a plastic opening tool between the midframe and the display assembly.
Work the plastic opening tool around the perimeter of the phone to break the adhesive.
Push on the battery housing to separate the midframe from the display assembly.
Use a set of tweezers to remove the two antenna cables.
Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
Turn the motherboard over.
Lift the metal tab up with the tweezers.
Turn the motherboard back over.
Unclip the two plastic clips that connect the rear camera to the motherboard with your fingers.
14 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
I change my LCD screen and camera stopped working. I bought new one and still no result. Please help !
stopped front camera
