Zum Hauptinhalt wechseln
Samsung Galaxy Note 4 Motherboard Replacement
Was du brauchst
  1. Samsung Galaxy Note 4 Motherboard Replacement, Rear Case: Schritt 1, Bild 1 von 2 Samsung Galaxy Note 4 Motherboard Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Motherboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 Motherboard Replacement, SIM Card: Schritt 3, Bild 1 von 2 Samsung Galaxy Note 4 Motherboard Replacement, SIM Card: Schritt 3, Bild 2 von 2
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
  4. Samsung Galaxy Note 4 Motherboard Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  5. Samsung Galaxy Note 4 Motherboard Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Note 4 Motherboard Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Note 4 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  6. Samsung Galaxy Note 4 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  7. Samsung Galaxy Note 4 Motherboard Replacement: Schritt 7, Bild 1 von 3 Samsung Galaxy Note 4 Motherboard Replacement: Schritt 7, Bild 2 von 3 Samsung Galaxy Note 4 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  8. Samsung Galaxy Note 4 Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Remove the two 2.9 mm Phillips #00 screws.
  9. Samsung Galaxy Note 4 Motherboard Replacement: Schritt 9, Bild 1 von 2 Samsung Galaxy Note 4 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Use a set of tweezers to remove the two antenna cables.
  10. Samsung Galaxy Note 4 Motherboard Replacement: Schritt 10, Bild 1 von 3 Samsung Galaxy Note 4 Motherboard Replacement: Schritt 10, Bild 2 von 3 Samsung Galaxy Note 4 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
  11. Samsung Galaxy Note 4 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the motherboard out of the phone.
Abschluss
110 weitere Nutzer:innen haben diese Anleitung absolviert.
Geoff Wacker
89.901 Reputation
89 Anleitungen geschrieben
66 Kommentare
Are all variants of the note 4 the same? An att mobo could go into a vzw/sprint body or vice versa?
Jeb - Antwort
I would also really like an answer to this question
pcwireless -
No. Even Samsung wouldn't accept even a paid repair because parts between models are incompatible.
I've tried to have an SM-910G here and if you are to replace it with an SM-910C, you'll also need to replace the front and back cameras.
Ian Troy Alvaran -
I have done a few Note 4 motherboard replacements...about 10 or so. I have not been able to simply "To reassemble your device, follow these instructions in reverse order." I always have to separate the screen from the mid frame in order to plug the 2 top ribbon cables back to the motherboard. I can't figure out a way to get the ribbon cables plugged back in without doing so. This screen separation process is very tedious, long, and stressful as it could crack the AMOLED screen if you're not careful. If someone can show me exactly how to simply, "To reassemble your device, follow these instructions in reverse order" it'll make it a lot easier for me. Thanks.
KengkoyFlip - Antwort
Agreed. That screen was by far the most difficult screen ive ever removed from a phone. It would be SOOO much easier if it were broken and you didn't care.
trentmrobertson -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 58
Insgesamt: 146,507
